Radio randomly shuts off
123,000 MILES • AUTOMATIC
GREENDAYROCKERCHIC
I got my oil changed at Michel's tires a few months ago. Since then, my radio will randomly shut off and I can not turn it back on myself, it has to come back on itself. Any idea what they did and how to fix it, cost as well? It is only the radio that does this, nothing else in the car acts up.
Aug 29, 2016 at 10:10 AM
SATURNTECH9
  • 30,868 POSTS
I can't think of anything they could have done from just a oil change to cause that.As far as what's wrong or how much to fix from the information I have I can't say.When it stops working does the display go out etc?
Aug 29, 2016 at 11:50 AM
GREENDAYROCKERCHIC
Yes, it is as if I pressed the power button on the stereo to turn it off. I think they messed with it on purpose to get more business or they accidentally knocked something loose, I do not know.
Aug 29, 2016 at 12:03 PM
SATURNTECH9
  • 30,868 POSTS
When it shuts off you would have to check the power and ground to radio to see if your loosing power or ground or have a issue with the radio itself.
Aug 29, 2016 at 12:09 PM
GREENDAYROCKERCHIC
Can a regular mechanic check that? Would it be a easy, cheap fix?
Aug 29, 2016 at 1:08 PM
SATURNTECH9
  • 30,868 POSTS
Yes a normal shop should be able to handle it. If it is a easy find and not the radio etc shouldn't be that expensive.
Aug 29, 2016 at 1:10 PM
GREENDAYROCKERCHIC
Okay, thank you for your input!
Aug 29, 2016 at 1:11 PM
SATURNTECH9
  • 30,868 POSTS
You are welcome.
Aug 29, 2016 at 1:12 PM
