Radio not working
247,242 MILES
LAUREN2442
My stock radio is not working. i have taken it out and everything looks fine, all the fuses are good. do i just need to get a new after market radio or is there anything else that could be as to why it’s not working ?
Sep 26, 2020 at 11:07 AM
  • 110,248 POSTS
When you turn it on, does it power up as if it should be working?
As far as an aftermarket, the wiring will require modifications unless you can get an adapter type plug to go from your vehicle to the radio you select. Often times it is easier getting an OEM radio from a salvage yard, but that is up to you.
Sep 26, 2020 at 11:09 AM
LAUREN2442
yes, it turns on but no sound is coming out. i have done everything but disconnect the battery.
Sep 26, 2020 at 11:14 AM
  • 55,721 POSTS
If the power and grounds are working the head unit has gone bad. here is a video of an aftermarket stereo in a similar vehicle:
https://youtu.be/jF_sDSS0n7I
This guide will help you test the power and grounds, I have also seen the clock spring go bad for the steering wheel controls cause the radio not to work.
BRADSTUEVE
The radio/CD/Cassette player work but the display is no longer lighting up.
Dec 15, 2020 at 7:03 AM (Merged)
There are a couple possible causes of this so we need to perform the attached testing and repair as needed. Let me know what questions you have with this and we can go from there.
DAVE LIMBERG
Radio seems to be okay, but no sound. Confused about your answer. Blue power antenna wire, where does that hook up? Last wire on black connector? Last number sequence, if that is the case which is pin one.
Have the infinity amp.
I have brown mute wire open.
I have blue with yellow open and blue with white open. P. Cont. Remote?
CARADIODOC
  • 34,414 POSTS
What is the rest of the story? If you are posting a new question instead of replying to the original question, new people will be coming in to the middle of your ongoing conversation and nothing will make sense.
It sounds like you are trying to install a lower-quality aftermarket radio and use the vehicle's remote amplifier. Unlike with GM and Ford systems that must be used as a matched set, Chrysler radios can all be used with or without the amp, but if not matched correctly, you will have too much or too little bass. Chrysler amps do not increase volume or power, so they can be used with an aftermarket radio, but they will not have the same tone response as the original one had.
The amp gets its turn-on signal from the circuit at the radio that could also turn on a power antenna. That is usually labeled as the "power antenna" wire on aftermarket radios, and in a loose attempt to standardize wire colors, that is typically a dark blue wire.
2CP-ARCHIVES
  • 4,540 POSTS
installed aftermarket stereo, mounting back into dash it lost power. Tried hooking up factory stereo it wont work now. I've checked all fuses in car and under hood, can't find nothing wrong with them.
CARADIODOC
  • 34,414 POSTS
What did you use for the ground wire? Which radio did you remove, a cassette radio, cd radio, or combo? Do you have the Infinity system with an amplifier?
WILLDILLINGHAM
My jeep radio does not work. It's wired correctly to the harness. I believe it's internal, any ideas?
Dec 15, 2020 at 7:10 AM (Merged)
DRCRANKNWRENCH
  • 3,380 POSTS
If you have exhausted all ideas and there is 12 volts getting to the radioe and it is not responding, it is most certainly internal.
I would reccomend getting a replacement as repair is not available.
DHRACER6061
  • 49 POSTS
I took the driver and passenger door off of my 95 grand Cherokee laredo and now the radio won't turn on. This is confusing because i did the same with my fourunner and it worked fine
CARADIODOC
  • 34,414 POSTS
Which radio model or style do you have? Does the display light up?
DHRACER6061
  • 49 POSTS
It's an aftermarket radio and no nothing lights up it almost seems like its unpluged but Idc if the power or ground had anything to do with the doors wiring
DHRACER6061
  • 49 POSTS
If it helps I didn't put the doors back on I took them off for off road purpose
CARADIODOC
  • 34,414 POSTS
Rats. I'm an expert on '90s Chrysler radios. I don't get involved with any aftermarket replacement models, but it sounds like you might just have a blown fuse. If your radio has a digital display, it will have two 12 volt feed wires; one is from the ignition switch to turn it on and one is live all the time for the memory. Some will not turn on at all if the memory fuse is blown. Some will work fine but the station presets and clock will reset each time you turn it on. Some will tune but won't have any sound.
The memory fuse is typically tied in with the interior lights but it could also be connected to anything else that's always live like the horn, brake lights, or cigarette lighter.
DHRACER6061
  • 49 POSTS
Is the stock radio harness tied into.the doors at all other than speaker wires?
YUKON78
95 jeep grand cherokee laredo Antanna does not go up either, was replaced 3 years ago. How can I fix it? pulled radio out but everything seems to be connected corectly
  • 31,937 POSTS
Could be a faulty amp if fitted or a blown amp fuse, i will look into it further.
DHRACER6061
  • 49 POSTS
The only thing after market is the sterio.all the speakers and stock harness is still hooked up
YUKON78
checked red fuse 10 and its for the radio and its fine.
CARADIODOC
  • 34,414 POSTS
It is possible to have a switched power wire going into the doors if the vehicle came with the Infinity system. They will have either a remote amplifier under the right rear seat or the door and rear speakers will have small amps bolted to them. Unlike the complicated GM and Ford systems that must be paired with an amp when it is used, all Chrysler radios put out speaker-level output. The amps do not increase volume or power. They only modify the tone response for the shape of the vehicle.
The easiest way to see if you have the Infinity system is to look at the plug on one of the speakers. If it has four wires, it is the Infinity system. If it has two wires, there's either a remote amp or it's not the Infinity system. The Infinity model radios look and work exactly like the non-Infinity models but they put out less bass. The bass is made up in the amps. With those speakers and an aftermarket radio you'll find the sound is more pleasing if you turn the bass down.
There's a few different ways the amp(s) can be powered. Normally if there's four speakers with amps, they are powered through a "speaker relay" or "amp relay". The high-current switched power circuit has its own fuse and that's the one that would blow if you grounded the power wire in the door while the ignition switch and radio were turned on. The radio would still have a display and it would operate normally but the only sound you would get would very tinny. The dash speakers, (I think) would work but only the tweeter part of the rear and door speakers would work.
The other way they can be wired is a single remote amp has its own turn-on circuitry that is triggered by the "switched power" wire from the radio. All aftermarket radios have that wire too. It can also be used to run a power antenna. In this system there is no power wire in the doors for the speakers so you shouldn't be popping any fuses. The amp still has its own fuse. Again, if it was blown the radio would operate but with no sound.
CARADIODOC
  • 34,414 POSTS
Hi guys. Most likely the problem is in the radio. Once those problems are repaired, they're repaired permanently. Sounds like you have a cassette-only or cd-only radio.
In the gray plug, measure the voltage on the two wires at the end away from the keyway. The first one is usually pink. It must have 12 volts all the time. The second one will be red, possibly with a stripe. It has 12 volts when the ignition switch is turned on. If the display lights up when you turn on the ignition switch, the red wire is okay. If the clock keeps the correct time, the pink memory wire is okay.
You can verify everything else is okay by jumping the red wire to the end wire in the black plug away from its keyway. That's the switched wire for an amp and / or power antenna. Jumping those wires might cause the radio to turn on too, depending on where the problem is located within the radio.
Also be sure the ground strap is bolted to the back of the radio or there is a wire clipped to it. There is no other ground wire in the two plugs. If that strap or wire is missing, the radio might work by getting grounded through the antenna cable, but that's a very poor ground for the power circuits. Typically when the ground is missing, the radio will be totally dead and the back lights won't turn on with the dash lights either.
If you have the cd player without cassette, that radio is built by Alpine. They are rather involved taking apart but that problem also is repaired permanently once it's been done. A common clue is the cd player does have sound. Only the radio has no sound. At the same time if you press either "Seek" button, you'll see the display advance very slowly, about one digit every three or four seconds. There is a different problem that affects only the FM and another one that causes intermittent display fading out. I address all of those when a dealer ships me a radio to fix. Also volume controls that respond poorly and front panel switches that perform the wrong function or don't work at all. I can be more specific if you tell me the model number from the sticker on top.
If you have a cd / cassette combo radio, that was not original in the Jeep in '95 but it will plug in and work fine if you can find one with the oddball mounting ears. Those are built by Mitsubishi and are REAL high quality. That mounting style was only used from '93 to '95 and only in the Jeep line, then again in the late '90s in the Avenger, but those had an orange display and back lighting.
DHRACER6061
  • 49 POSTS
Ok thanks I'll check all this out. I just want my radio back. Haha
  • 31,937 POSTS
You need to check all fuses in pic, use atest light if you have one.
CARADIODOC
  • 34,414 POSTS
Hi guys. This is commonly a problem in the radio. Rather than retype everything I did last night, then lost when the web site went down, I can give you a lot more information if you tell me the radio model number or if it's a cassette-only or cd-only radio. Most of the problems are with the cd-only radio. It's built by Alpine and has a number of problems that are fixed permanently once repaired.
First you can check for 12 volts on two wires in the gray plug on the end away from the keyway. The first one, usually pink, must have 12 volts all the time. The next one, red, and possibly with a stripe, must have 12 volts when the ignition switch is turned on. If the display turns on when the ignition switch is turned on, that red wire is okay. If the clock always maintains the right time, the pink wire is okay.
Also be sure there is a braided ground strap bolted to the back or a black wire clipped to the back. There is no ground wire in either plug. The radio can work if it grounds through the antenna cable, but that's a real poor ground for the power circuits.
If you have the cd-only radio, they lose sound on just the radio. The cd player should be okay yet. The additional clue is when you press either "Seek" button, the display will advance one digit very slowly, perhaps once per three or four seconds.
There is a different problem that causes no sound just on FM, and another one that causes the display to fade out intermittently. When a dealer ships one to me for repair, I address all of those issues at the same time. Also, the volume control can respond erratically and the front switches might perform the wrong functions or not work at all.
If you have a cd / cassette combo radio, those were built by Mitsubishi and are REAL high quality. They did not come in the '95 Jeeps as original equipment. Any other Chrysler radio will plug in and work but the '93 - '95 Jeeps used different mounting ears than all the other Chrysler products and years. The only original combo radio that will mount was found in the late '90 Avengers but they had orange displays.
If voltage is missing to the pink wire, look for a blown interior lights fuse, usually a 10 or 15 amp. Also look for a fuse for the remote amplifier. Some models used an amp under the right rear seat. As I recall, if the fuse is blown, you'll have no sound at all on any function. Some Infinity models used little amplifiers bolted to the speakers. If the fuse is blown, those will still have some very tinny sound from the tweeters. They are not powered by the amps. Any amplifier-related problem will affect the radio, cassette player, and / or cd player. If anything works, the amp is okay.
The ground for the relay that turns the amp on is that black wire clipped to the back of the radio.
DAVID WASSELL
my radio wont work the fuse is good. my turn signals blink very slowly what should i do?
UDMAN2006
  • 13 POSTS
Where is the relay or fuse for the amp? I have a similar problem with no sound from the speakers in any mode.
CARADIODOC
  • 34,414 POSTS
Check the charging system. Measure the battery voltage with the engine running. It must be between 13.75 and 14.75 volts.
Also check the battery. With the engine off, the voltage should be 12.6 volts. 12.2 volts means it's good but discharged. If you find closer to 11 volts, the battery has a shorted cell and must be replaced.
CAMREN
Hi, I own a 1993 Jeep Grand Cherokee Laredo and am having issues with the radio; it has power but when you actually turn the dial for the radio for a listen it seems to generate no sound and the radio stations disappear and do not return on the display ...I have check the fuses, the wiring and the antenna; all seem clean, clear and connected...what else could be wrong?
CARADIODOC
  • 34,414 POSTS
Do you have the factory cd player? Do you know the model number?
CAMREN
I have the factory install, a cassette player model #56007113, issue: ZJ Cass 1 1, date code/serial # 0683 00036929 if that helps
CARADIODOC
  • 34,414 POSTS
When you say the radio stations disappear, do you mean the display goes blank or it goes back to the clock? If it goes to the clock, the problem is with the on / off switch. Other technicians used to replace the entire volume control assembly for this problem when the parts were still available, but they would develop the same problem in a few years. I take the power switch apart and repair it permanently. I've done hundreds of these for dealers and only had two come back a second time. If you'd like me to fix yours, it's $35.00 including return shipping. If interested, I'll send you my contact information privately and some packing hints to prevent shipping damage. It takes about one day to get it back in the mail after I receive it.
CARADIODOC
  • 34,414 POSTS
Forgot to mention, you can prove this is the problem by cycling the switch off and on multiple times. Eventually it will work, but that also makes it get worse.
