Radio lock-out
195,000 MILES • 6 CYL • 4WD • AUTOMATIC
JMCORNWALL
After a drained battery the radio is black. no sign of life. I have checked the fuse under the passenger side, but it is good.
I have tried any YouTube suggestions I could find. Holding down 1 and 2 buttons, trying in the accessory key position, etc. etc.
I look to you, for your wisdom.
Feb 20, 2018 at 5:23 AM
STEVE W.
  • 15,392 POSTS
First thing is to try removing the battery cable and waiting a few minutes. Reconnect and see if the radio shows any life. Next check all of the fuses using a test light,
https://www.2carpros.com/articles/how-to-use-a-test-light-circuit-tester (step 3)
If the fuses all test good and still no life in the radio it is probably bad.
Feb 20, 2018 at 6:14 PM
JMCORNWALL
Thank you so much! As simple as removing the battery cable for a few moments.
Feb 21, 2018 at 2:20 AM
STEVE W.
  • 15,392 POSTS
It can be. I have seen them lock out for that. If it does not work you have the option of replacing with OM or after market.
Feb 21, 2018 at 2:25 AM
