Radio lock did not set code?
83,000 MILES
HUX
Transmission was replaced on vehicle a while back. I had not driven car much as it was shortly before illness. Now I realize radio is locked. We did not set code don't know if dealership did. I called dealership (as they replaced Transmission) and have been told I have to bring it in and they will fix for$300. That is stupid. I have a Honda i founf a number i gave them the vin and they gave me the code. I have done what research I can and found the "scrambled code". GM still wants to charge for code. Is there a way just to get my stupid code? Also once in the LOCK mode how do I get it back to ---- to put in new code. I'm rather frustrated. I have a nice sterio, it would be nice to be able to listen to it. Thanks!
Jan 14, 2026 at 3:39 AM
STEVE W.
  • 15,409 POSTS
GM used to have radio unlock hotline that you could call, you then entered the numbers you got from the radio and you would get the unlock code. That system was shut down a couple years ago when GM decided that it wasn't getting enough use to keep it going. The codes then fell back into dealer only territory. From LOC you can usually get to the code entry screen by holding down the 1 and 4 buttons, turning the ignition on then keep holding for about 7-8 seconds, you should see SEC come up and then you can enter the code. Getting that code isn't easy anymore though. To get the code you need the radios serial number, the VIN and the unlock ID you already have. Then try a couple dealers, some don't charge while others do. Also if you have the original owners manual the code was commonly in them. There were a few more common codes like 2174 and 2431 but I have no idea if those would work. Be advised that if you enter the wrong code the radio can shoe INOP and then you have to keep the key on but not run the engine for an hour before you can reset it and try again. This is one of the reasons why many remove the stock units and install aftermarket ones. Plus those generally allow for things like blue tooth and more.
Jan 14, 2026 at 4:05 PM
