Replaced after market radio three times still not working
41,832 MILES • 5.0L • V8 • 2WD • AUTOMATIC
AARON MAXON
I bought the truck with a after market radio in it. One day while driving the radio cut out, so I replaced it (twice) and still couldn’t get it to turn on. I have 12 volts switched, 12 volts constant and ground. I find it hard to believe that three radios are all bad. Any suggestions? Assistance will be greatly appreciated. Actually the truck is a Scottsdale, but that wasn’t listed, or C-10.
Feb 5, 2019 at 3:44 AM
KENW1
  • 213 POSTS
Thanks for visiting 2CarPros.
While it is unusual to see this many radios bad in a row I have run into it with more bargain brands like Boss or Dual.
What I suggest is with your meter or test light hoked up move the harness around to see if you have an intermittent open circuit or ground.
Feb 5, 2019 at 9:33 AM
