Radio draining battery?
81,000 MILES • V6 • 2WD • AUTOMATIC
LUVENIA CLARK
Car wouldn't start and after boosting it started, however my IntelliLink screen went black. I drove to the mechanic and was told the radio was causing the battery to drain even when the radio was off.
Jan 4, 2025 at 12:24 AM
  • 55,691 POSTS
It could be a control module not shutting down, did the mechanic do a CAN scan? This is what needs to be done to see what codes are stored. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is a guide that goes over the most popular reasons for the battery to drain down over night:
https://www.2carpros.com/articles/car-battery-dead-overnight
I have seen the Multi-media interference control module go out and cause this, but codes would be better. Please go over these guides and get back to us.
Jan 5, 2025 at 6:48 AM
