Radio works screen does not
20,000 MILES
STICKMONRED
Suddenly the display screen is blinking, showing strange gibberish characters. The clock and radio stationsand on screen controls are no longer visible on the panel.
I tried disconnecting the battery, putting in the five digit anti-theft code, but that did not solve the problem. The radio still works, but the screen does not.
Oct 28, 2017 at 4:22 AM
  • 31,937 POSTS
The integrated display has probably failed. you may be able to see if your dealer has an up grade program that may fix the problem, otherwise it may be a case of a new display unit.
Oct 28, 2017 at 9:48 PM
