Radio dash kit
36,000 MILES • 6 CYL • 4WD • AUTOMATIC
FEBBY WAP
  • 23 POSTS
Hi I have a FJ cruiser and I just installed a 7” radio and now there is a space on the left and the right side of the radio compared to the original cover. I have tried finding radio dash kits for it however I am unable to find it. Does anybody have any suggestions? Thank you!
Mar 19, 2019 at 9:59 PM
CJ MEDEVAC
  • 11,000 POSTS
Trim out what you need.
If the radio is "sucked in" to the dash, you may have to trim it a little closer to the radio. A hair dryer or heat gun (careful with the heat) may help it settle into place if it's a little wavy.
Work it to suit!
You probably have two tries with the one notebook!
I've done this a few times with black notebooks on other vehicles.
Let me know what you think.
Pic below
The Medic
Mar 20, 2019 at 9:25 AM
FEBBY WAP
  • 23 POSTS
Thank you so much!
Mar 20, 2019 at 11:08 AM
CJ MEDEVAC
  • 11,000 POSTS
I hope it works out for you if you go that route.
Regardless of what you do, send us a picture of the finished product and let us know what actually did work for you!
In the long run, your fix might help someone else that might be searching 2carpros to make their own repair.
The Medic
Mar 20, 2019 at 11:15 AM
FEBBY WAP
  • 23 POSTS
Yes definitely thanks! It’s actually a perfect fit up and down and it’s parallel with the cover but there is just a space in between the left and right. Is there another option by any chance?
Mar 23, 2019 at 9:49 AM
CJ MEDEVAC
  • 11,000 POSTS
I'll see if some of the other 2CarPros have any ideas.
The Medic
Mar 23, 2019 at 11:32 AM
FEBBY WAP
  • 23 POSTS
Okay, thanks! Really appreciate the help!
Mar 23, 2019 at 12:50 PM
DANNY L
  • 5,648 POSTS
There is an aftermarket company that makes radio dash pieces/harnesses/trim /adapters,etc called METRA. You can find them online.. Hope this helps and thanks for using 2CarPros.
Danny-
Mar 23, 2019 at 12:58 PM
FEBBY WAP
  • 23 POSTS
Thanks!
Mar 23, 2019 at 2:47 PM
HARRY P
  • 2,292 POSTS
Check amazon and Ebay for the above referenced Metra kits. Otherwise you can go to a car audio retailer and check with them or maybe a custom car shop can fabricate something at a not horrible price.
Mar 23, 2019 at 9:54 PM
FEBBY WAP
  • 23 POSTS
Okay, thanks!
Mar 24, 2019 at 1:37 AM
