The left turn signal blinks very fast while right turn signal is normal.
If it is the BCM I can find no replacement for it as it is discontinued
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the lighting concern and radio power concern diagnosed individually before assuming a shared module failure. Document bulb specifications, socket condition and the affected circuits' power and ground checks using the vehicle wiring diagram. A visual fuse check and lamps that still illuminate do not constitute a completed circuit diagnosis. Request test evidence before replacing the radio or sourcing a BCM.
2CarPros: Original discussion 1712473 https://2carpros.com/questions/radio-clock-stopped-working-and-left-turn-signal-is-very-fast Source for the owner's reported history and outcome. Contributor suggestions are not independently confirmed diagnoses. No attachment content was verified. Fluke: Diagnosing voltage drops https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting General support for testing electrical supplies and connections under load. Use the actual vehicle's circuit diagram and test limits; this reference does not diagnose the reported fault.
left turn signal is very fast?
The owner reported that the radio and clock stopped working and the left turn signal flashed rapidly while the right side operated normally. The owner said both cited fuses had been checked and both left lamps still flashed. Bulb and socket inspection was suggested, followed by speculation about the BCM.
Reported outcome: No faulty component or successful repair was confirmed.
The fuse numbers and module attribution in the replies were not independently verified. The discussion supplies no loaded voltage measurements, scan results or completed bulb/socket inspection.
