Radio and Navigation system anti theft lock
146,789 MILES
IVYKOMYO
I have a problem. After changing car battery, it is appear Anti theft lock.
Apr 19, 2019 at 5:10 PM
  • 55,684 POSTS
Yep, when the battery is replaced it can trigger the security system to be engaged. here is a guide to help you reset the system:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Apr 22, 2019 at 8:52 AM
IVYKOMYO
My problem is radio and navigation system anti theft lock.
Only car radio and TV was not work.
There is no alarm and no other problem.
I can drive anywhere.
Everything is okay expect TV, DVD and navigation.
Japanese words appear, and it can touch characters (eng/jap) and numbers for typing anti theft code.
Apr 22, 2019 at 9:53 PM
  • 55,684 POSTS
Opps, you lost some of the programming. Did the battery cables get reversed or was the battery jumped backwards? Sometimes a voltage spike from connecting the battery cables can cause this as well. Lets run the codes to see what comes up. here is a guide:
Apr 23, 2019 at 4:24 AM
IVYKOMYO
That isn't my problem.
My car is still running. There is no problem except radio, navigation system.
Not for engine. No alarm, no check light.
I mean radio antithef lock.
Can't use radio, dvd player, map and back camera.
Thanks for your answer.
We appreciated that.
Jul 21, 2019 at 9:55 PM
  • 55,684 POSTS
It looks like the unit shorted out after charging the battery I am wondering if the voltage was too high causing the issue. Did you try installing the code? Let check the fuses to make sure we are all good there. here is a guide and the fuse locations:
If the fuses are okay here is how you can remove the radio/navigation for repair. Check out the diagrams (below). Please let us know what happens.
Jul 22, 2019 at 3:51 AM
