radio will not stay programmed
192 MILES
RICKY ROWLAND
  • 11 POSTS
When I program the radio stations they stay programmed as long as the car is on once I turn the car off the stations goes away when I turn the car back on the stations are no longer programmed and the radio is always turned off ( even though it was on when I turned the car off ). help would be appreciated.
Jan 23, 2017 at 9:50 AM
CARADIODOC
  • 34,415 POSTS
Check the fuse for the memory circuit. That is always tied in with some other circuit that is always live. Most commonly that is the interior lights circuit, but it could also be the horn, brake lights, or in some cars, the cigarette lighter. Toyota also hides a red 10-amp fuse on the back of the radio.
Jan 23, 2017 at 9:56 AM
RICKY ROWLAND
  • 11 POSTS
Thanks, I will look at that.
Jan 23, 2017 at 10:10 AM
