change radio out had it unlocked every thing works but on sound.
Feb 10, 2017 at 12:11 AM
STEVE W.
✓Experienced Mechanic
Which stereo did it have from the factory and which did you replace it with? Depending on the option package it can have a couple remote amplifiers and if you used a different stereo it's possible the amp(s) are not turning on.
Feb 10, 2017 at 2:52 AM
TEASDA4321
MEMBER
are they any thing i can do
Feb 10, 2017 at 3:19 AM
STEVE W.
Which stereo did you remove and what did you put in? The wiring is different depending on the units and options so telling you to check a green wire won't help if you don't have a green wire. I show at least 4 different wiring diagrams, some 2-3 pages.
