radio will not stayed programmed
194,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
RICKY ROWLAND
  • 11 POSTS
When I program the radio station they stay programmed as long as the car is on once I turn the car off the stations goes away. when I turn the car back on the stations are no longer programmed and the radio is always turned off ( even though it was on when I turned the car off).
Feb 6, 2017 at 8:40 AM
CJ MEDEVAC
  • 11,000 POSTS
Check radio 1 Fuse (20 amp).
Engine room J/B 2 (Left side of engine compartment).
This fuse should be hot/ powered at all times
The Medic
Feb 6, 2017 at 8:56 AM
