How to set the radio stations
100,000 MILES • 5.9L • AUTOMATIC
ANDREW CUNEO
i do not know how to set radio stations. please help. This is a 2500 pickup.
Feb 20, 2018 at 6:42 AM
CARADIODOC
  • 34,415 POSTS
Depends on the model of the radio. If you have the base radio with or without cassette, press the "set" button, then the "Sel" button. That will display the hour. Use the rotary tuning knob to set the hour. Press "Sel" again to switch to minutes, then set them the same way. Press "Sel" to go back to normal mode.
Feb 20, 2018 at 10:33 AM
ANDREW CUNEO
i need radio set help
Feb 20, 2018 at 12:37 PM
ANDREW CUNEO
i need radio help to pre set stations in my 2500 truck.
Feb 20, 2018 at 12:41 PM
JOHNNY G.JR
  • 320 POSTS
Have you looked in owners manual,or called a Dodge dealership?
Feb 20, 2018 at 12:54 PM
CARADIODOC
  • 34,415 POSTS
Did you even read my reply?
If my procedure does not apply to your radio, post a photo of the face plate.
Feb 21, 2018 at 9:16 AM
ANDREW CUNEO
it did not tell me anything.
Feb 21, 2018 at 10:54 AM
CARADIODOC
  • 34,415 POSTS
Boy, am I stupid. You asked twice how to set the stations and I told you exactly how to set the clock. Sorry.
On most models, tune the station you want, then press the "Set" button. Press the preset number button you want to be for that station, and that is it.
The higher-end models can set 10 AM and 10 FM presets. To put the first one in memory for preset number 1, tune the station, press "Set", the display will show "Set 1", press preset "1" and you are done. To do a second station, press "Set" two times. The display will show "Set 2". Press preset number "1", and the second station has been set. Now, when you press preset button number "1", you will get the first station you put in memory. Press "1" again and you will get the second station you put in memory. Each time you press "1", you will toggle between those two stations.
Feb 21, 2018 at 11:18 AM
