Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
All Other Makes
All Other Models
Engine Cooling
Radiator
Radiator trouble
2003 ALL OTHER MAKES ALL OTHER MODELS
18 MILES • TURBO • 2WD • MANUAL
MøHàMêð SâLêéM
MEMBER
1 POST
When my car engine is heat. It is not decrease heat. sometimes radiator water boils.
Tata indigo ls 2003
May 6, 2017 at 3:55 PM
Experienced Mechanic
It sounds like you could have a coolant leak or the radiator fans are not coming on. Here is a guide that can help you get the problem fixed.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
May 9, 2017 at 4:54 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
