Radiator problem
150,000 MILES
GABBYDELGADO1769
The cap to my radiator has an outgoing plastic piece to a hose that hose has disconnected due to the piece that was connected that was plastic has broken or melted or disconnected. is there anyway I can fix it without replacing the whole radiator itself?
Nov 7, 2017 at 4:08 AM
WRENCHTECH
  • 20,760 POSTS
I don't think so. I have had to replace many a radiator for that reason. That is a pressure connection and no type of epoxy will hold.
Nov 7, 2017 at 6:44 AM
GABBYDELGADO1769
I had a mechanic come and check it out and yes that part is and was replaced. it is called, coolant filler neck for anyone who also needs help.
Nov 7, 2017 at 10:09 AM
  • 55,560 POSTS
You can repair this kind of repair if you drill and thread a brass hose fitting into the end of the hole on the neck. I have never seen a replaceable filler neck but there is always a first.
Here is a guide on what you are in for when replacing the radiator:
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
Cheers, Ken
Nov 9, 2017 at 6:52 AM
