Radiator overheating or burning coolant
50,900 MILES • 1.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
XNOCAP
I’m just now getting codes for misfiring of some ejectors but the day before everything was running fine. I don’t see oil in the radiator or transmission fluid either.
I checked the oil no chocolate slush.
Did a compression test no crack or leak anywhere.
Dec 17, 2019 at 2:35 PM
SCGRANTURISMO
  • 4,897 POSTS
So is your vehicle losing coolant? If it is the best way to figure out where it is leaking from is to do a cooling system pressure test. Here is a link below explaining how to do it:
https://www.2carpros.com/articles/radiator-pressure-test
Please go through this guide and get back to us with what you find out.
Thanks,
Alex
2CarPros
Dec 17, 2019 at 9:09 PM
