Overheating reservoir boiling?
1,200,000 MILES • 2.2L • 4 CYL • AUTOMATIC
DEBBIE ESPINOSA
Replaced the thermostat and housing, still hot. So, I did a flush, still boiling hot. I thought maybe a gasket leak and so did blue glass. Still overheating not boiling but temperature going to red. Also replaced air temperature sensor and also replaced the coolant temperature sensor.
Sep 24, 2022 at 8:55 AM
SQM
  • 6,383 POSTS
An engine can overheat due to a number of reasons. You have already covered the thermostat and temperature sensor. It could also be due to a faulty water pump, clog in the coolant system, bad radiator, inoperative cooling fans.
Was there coolant mixed with oil?
Take a look at this guide, it goes over the usual issues and diagnostics:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Let me know what you find.
Sep 24, 2022 at 11:12 AM
