Just curious what that upper passenger side aluminum line is going into the radiator
165,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
SACFOX186
  • 38 POSTS
Upon removing the fans it was in the way and i disconnected it so the fan could come out, but didn't connect it until a day later. Since it's connected ,can i drive my car without trouble. since it's supposed to be a closed system?
Oct 13, 2020 at 2:28 AM
Good afternoon,
That line is for the transmission cooler. I attached a picture for you of the location of the line. You do need to remove that to get the fans out.
https://www.2carpros.com/articles/replace-electric-fan-motor
As far as your question, no, it does not harm leaving it disconnected for a day. You are good to hook it back up and go.
REMOVAL
1. Remove upper radiator crossmember.
2. Disconnect fan electrical connector.
3. Remove fan module attaching fasteners and clips.
4. Remove fan module by lifting upward to clear radiator.
INSTALLATION
1. Install fan module.
2. Install mounting clips and fasteners.
3. Connect fan module electrical connector.
4. Install upper radiator crossmember.
Oct 13, 2020 at 3:12 AM
SACFOX186
  • 38 POSTS
here is one last question, hopefully: when i start up the car now it seems to go at a higher rpm than curb idle for at least 20 seconds then it calms down. is that a dirty throttle body? if so, it's so close to the firewall how do you get to it?
Oct 18, 2020 at 8:30 AM
We can deal with one issue at a time as per site rules.
Since we are beyond the fans, you need to start a new question.
I will be happy to help when you start a new question.
Oct 18, 2020 at 8:34 AM
SACFOX186
  • 38 POSTS
never mind, i'll look on that app Mitchell1,which only shows old time cars, the kind i remember, the carburetor ones on top. and no info whatsoever. which i mistakenly paid 20USD. i'll revert back to YouTube university, lol.
Oct 18, 2020 at 8:35 AM
Okay, good luck.
Feel free to reach out to us if you have any questions.
Oct 18, 2020 at 8:41 AM
