Radiator leak
176,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
JOHN DEVANE
Radiator leaks down at about 23 miles of driving, engine does not overheat.
May 27, 2016 at 2:59 AM
HMAC300
  • 48,601 POSTS
have this checked for a head gasket failure have it pressure checked first. Then there is a chemical they can add to check further.
May 27, 2016 at 5:06 AM
JOHN DEVANE
pressure check has been done.
May 27, 2016 at 6:54 AM
HMAC300
  • 48,601 POSTS
when it is hot check radiator for cold spots if it has those as well as loose/green colored fins on edges and bottom or just cold spots then the rad is bad. I am assuming the thermostat is in good condition and not stuck and no leakage anywhere on engine like hoses or freeze plugs.
May 27, 2016 at 9:24 AM
JOHN DEVANE
I have replaced the water pump, heater hose connector ,coolant sensor, thermostat and the water pump adapter housing. I will check for cold spots next.
May 27, 2016 at 11:19 AM
  • 55,721 POSTS
Hey John,
Have you checked the passengers side floor for coolant, sometimes when the heater core let's go it can leak there. Also can you do a chemical check for a blown head gasket?
Here is a guide to help
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
and
https://youtu.be/5zpNjYmmiYY
Let us know what you find
May 29, 2016 at 1:17 AM
