Radiator leaks down at about 23 miles of driving, engine does not overheat.
May 27, 2016 at 2:59 AM
HMAC300
✓Experienced Mechanic
have this checked for a head gasket failure have it pressure checked first. Then there is a chemical they can add to check further.
May 27, 2016 at 5:06 AM
JOHN DEVANE
MEMBER
pressure check has been done.
May 27, 2016 at 6:54 AM
HMAC300
when it is hot check radiator for cold spots if it has those as well as loose/green colored fins on edges and bottom or just cold spots then the rad is bad. I am assuming the thermostat is in good condition and not stuck and no leakage anywhere on engine like hoses or freeze plugs.
May 27, 2016 at 9:24 AM
JOHN DEVANE
MEMBER
I have replaced the water pump, heater hose connector ,coolant sensor, thermostat and the water pump adapter housing. I will check for cold spots next.
May 27, 2016 at 11:19 AM
Hey John,
Have you checked the passengers side floor for coolant, sometimes when the heater core let's go it can leak there. Also can you do a chemical check for a blown head gasket?
