Radiator leak
110,000 MILES • 3.0L • 6 CYL • RWD • AUTOMATIC
NORTHGABOY
  • 13 POSTS
A week ago, I had to replace the thermostat on my 2003 BMW 530i, and unfortunately during this process I accidentally broke the little L-nipple that is on the top driver's side of the radiator (the one that the hose connects to that runs to the coolant reservoir tank). Also during the process, I broke one of the little tabs on top beside it as well. I tried to JB Weld it back, but have since noticed a real small leak. I finally found & ordered a couple new fittings (part #: 17 11 0 419 132) and I was wondering if it is possible to remove the JB Weld and replace this fitting without having to replace the entire radiator?
Mar 14, 2016 at 10:19 PM
CJ MEDEVAC
  • 11,000 POSTS
ANYTHINGS IS WORTH A TRY!
IF YOU GET IN A BIND, THIS LOOKS TO BE YOUR ANIMAL
http://shop.advanceautoparts.com/p/carquest-radiator-432526/20920066-P?searchTerm=radiator
JEEPERS! (THAT WOULD BE MY CHOICE IN A RIDE!)
MAYBE THIS WILL SAVE YOU $40 IF THINGS SEEM TO TURN SOUR
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
A124 MAY STILL WORK, TRT41 WORKS IF YOU PASS THE $100 MARK (TRT41 WORKED FOR ME RECENTLY)
DO A DRY RUN THRU THE CHECKOUT TO INSURE THE CODE STILL WORKS
LEMME KNOW IF THIS HELPS
THE MEDIC
Mar 15, 2016 at 1:08 PM
