Radiator housing issue
156,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
CARANSWERS101
  • 5 POSTS
I was working on my car and accidently snapped a stud that holds the thermostat. What is the replacement stud part number for the thermostat housing?
Nov 22, 2020 at 11:15 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I've attached a picture below of the thermostat housing to see if these studs are what you're talking about. Also, Is there enough broken stud left sticking out to remove with vice-grips are you going to have to use a screw extractor? Let me and we'll go from there. I will get you the part number. Hope this helps and thanks for using 2CarPros.
Nov 22, 2020 at 12:48 PM
CARANSWERS101
  • 5 POSTS
Hello, yes that is correct! I already removed the top stud. What is the part number please?
Nov 23, 2020 at 3:41 AM
Good morning,
Since you have the other stud removed, I would go to Fastenal or the dealer if you wish to match up the stud.
I see no part number in any of my catalogs.
This only run about bucks.
Nov 23, 2020 at 9:29 PM
CARANSWERS101
  • 5 POSTS
Okay. I will keep looking.
Nov 23, 2020 at 11:18 PM
Fastenal is the best place to go.
Nov 23, 2020 at 11:24 PM
CARANSWERS101
  • 5 POSTS
I checked but I'm having trouble with the dimensions. I want to order the correct size.
Nov 23, 2020 at 11:25 PM
Take the other stud you removed with you to match the thread sizes.
Nov 23, 2020 at 11:27 PM
CARANSWERS101
  • 5 POSTS
I found spare studs in my tool box. Cut off the head with a hack saw and it works perfectly. Thank you guys for your help and patience. You're awesome!
Nov 24, 2020 at 1:57 AM
You are welcome.
Always glad to help.
Nov 24, 2020 at 2:13 AM
DANNY L
  • 5,648 POSTS
Hello again.
If you want to avoid all that hassle just go with the Toyota factory replacement stud the Part Number is 9012606022. The price is $3.72 a piece. Available at any local Toyota dealer. Hope this helps and thanks again for using 2CarPros.
Danny-
Nov 24, 2020 at 4:48 AM
