radiator hoses
116,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
PCULQUI
  • 354 POSTS
I purchased the CSF 3637(part number) radiator from Rock Auto. I need to know which radiator hoses and if that may, thermostat and gasket are compatible with this radiator I purchased.
Mar 20, 2021 at 11:57 PM
Good morning,
It is Roy again. Did you match up the hoses I posted to what you have? I sent you pictures and part numbers for the hoses.
What brand and part number radiator did you already purchase?
Mar 21, 2021 at 11:20 PM
PCULQUI
  • 354 POSTS
I purchased the CSF 3637 radiator from Rock Auto. I did receive the pictures for the hoses, thermostat, gasket and radiator. But since I already purchased a radiator, will these hoses, thermostat and gasket fit the radiator I purchased?
Mar 21, 2021 at 11:28 PM
They should fit the radiator as they are the ones listed for that part number.
Mar 21, 2021 at 11:36 PM
PCULQUI
  • 354 POSTS
Only because you had suggested a radiator on your list of items.
Mar 22, 2021 at 2:17 AM
Okay, sounds good.
Mar 22, 2021 at 2:26 AM
