Those numbers are specific to that hose manufacturer. We never go by that. Instead, simply go by the application. The people at the parts stores will ask for the car model, engine size, year, and sometimes whether or not it has air conditioning. If there are any other options or variables, they'll ask you that too.
Years ago, it was common to get a new hose that had to be cut to length to fit your application. They did that to reduce the number of different hoses they had to stock. On some models or with some engine sizes, you used the new hose as is, and in some other applications, it took the same hose but a few inches shorter on one end. We don't see that much anymore, but when we did, there was usually a sticker wrapped around that end of the hose, with a line showing where to cut it if necessary.
You can also look up the hose on sites like for Rock Auto. I use that site a lot for reference. After you click on the brand, year, model, and engine size, you'll get a menu to click on "Cooling system", then "Radiator hose". From there, you'll find the hoses listed by application from up to dozens of different manufacturers / suppliers. Almost every one of them includes a blue "Info" button where each supplier provides detailed descriptions or installation advice.
I found a dozen listings for the upper and lower hoses, from $18.00 to $42.00. As a general rule of thumb, for this type of part, the least expensive ones are typically equivalent to what came new on the car, and the more expensive ones come with some feature, or "improvement" that makes them worth more.
I got stumped at first. I clicked on, "Coolant hose / pipe" by mistake. You want "Radiator hose" further down on the list. It was nice to find that first listing. GM has a history of failing small specialty hoses that local parts stores and even dealers rarely stock.
Let me know if you need more help finding the right hose.
Nov 20, 2026 at 5:52 PM
