Radiator grille soaked with coolant
171,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
JIMMIE ROBINSON
Thursday, I had a coolant leakage due to my coolant fan exploding because a rock came up through the shroud and well caused a lot of damage. It put a hole in the lower radiator hose, high pressure power steering hose was also cut, the shroud and the fan were destroyed. I fixed the all the issues but I noticed that my back grille had the bottom portion soaked in coolant. This is after I replaced the faulty hose and topped off fluids. Is this a problem or should I let it run?
- Jimmie
P.S. Today is the following Monday so I thought that the fluid should’ve dried up by now.
Apr 1, 2019 at 9:38 AM
Good evening,
Did you pressure test the system after your repair to verify no leaks?
https://www.2carpros.com/articles/radiator-pressure-test
Yes, it should have dried up by now.
Apr 1, 2019 at 10:07 AM
JIMMIE ROBINSON
I have not done a pressure test but it has been driven around about fifteen miles. And the upper hose has resistance when squeezing it.
Apr 1, 2019 at 10:12 AM
I would pressure test it.
You could also go to a self serve car wash and clean off the grille and watch for leaks.
Apr 1, 2019 at 10:17 AM
