Radiator fluid and oil leak
20 MILES
KYNDE N. MOON
Hi, I had never changed my spark plugs before but when i finally did, they were terribly corroded. With these new spark plugs, my radiator fluid and oil have been leaking by the gallons daily. is there any correlation? what should i do?
Jan 3, 2018 at 6:08 AM
  • 55,628 POSTS
There should be no correction between doing the plugs and leaking coolant and oil.
Here are two guides that will help us see what the problem is:
https://www.2carpros.com/articles/engine-is-leaking-oil
and
https://www.2carpros.com/articles/car-is-leaking-coolant
Cheers, Ken
Jan 4, 2018 at 8:10 AM
