Radiator fans run with engine off
280,000 MILES • 3.8L
KRUSTY MCLAIN
Fan wont shut off, until battery is dead.
Jul 7, 2019 at 3:40 AM
Good afternoon,
There are a couple of possibilities.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
1. Relay stuck closed.
2. TIPM or totally integrated power module grounding the relay.
3. PCM not releasing ground to the relay.
You need an advanced scan tool to monitor the fan controls.
I attached a wiring diagram for you to view.
Jul 7, 2019 at 3:57 AM
