radiator fan starts with engine on
64,000 MILES
NADEEM5565
  • 14 POSTS
my car radiator fan starts with engine starts is it a problem if I Drive without repairing it .....also my car starts after 5 to 6 cranks every day . One year back i changed my fuel pump ,ignition coil crank shaft sensor .due to not at all starting
Apr 11, 2013 at 11:34 PM
there is a issue with the fans and it needs too be corrected before you create more issues.
check the fuel pressure for the delayed start
Apr 13, 2013 at 10:00 AM
