Radiator fan not working
234,654 MILES • 6 CYL • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
Hello, the vehicle's radiator fan stop functioning. When I tested the fan directly by connecting battery to it, it function properly. Then the fault is within the circuit. Could you help me with the circuit diagram?
Feb 24, 2021 at 4:54 AM
  • 110,248 POSTS
First, I attached two pics below. They show the entire circuit for the cooling fans. I had to cut the pic in half to make it readable, but I did overlap them so you can follow them.
Now, the first things I would check are the fuses and fan relays. In addition to simply checking the fuse, confirm there is power to and from it. Here is a link to help with that:
Next, check the relays in the underhood fuel/relay box. If there are relays with the same part numbers, switch them. If there isn't, here is a link explaining how to check a relay:
Pic 3 shows the relay location in the box. Pic 4 shows the fuse to check and relay 1.
____________________________________
I hope this helps. Let me know what you find or if you have other questions.
Take care and God Bless,
Feb 24, 2021 at 12:30 PM
BLESSING EWOBOR
  • 753 POSTS
Feb 24, 2021 at 2:40 PM
  • 110,248 POSTS
You are very welcome. Let me know how things turn out for you or if you have other questions.
Feb 25, 2021 at 9:56 AM
BLESSING EWOBOR
  • 753 POSTS
Okay.
Feb 25, 2021 at 12:40 PM
