Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Santa Fe
Engine Cooling
Cooling Fan
Replace/Remove
How do I remove the top fan of the radiator fan to get to the motor?
2002 HYUNDAI SANTA FE
113,000 MILES • V6 • 2WD • AUTOMATIC
JBOX
MEMBER
1 POST
the screws to unscrew it are being blocked by the fan so I can’t reach them. so how do I pull these front fan blades off?
Apr 15, 2025 at 3:24 PM
Experienced Mechanic
Yes, you need to remove the fan blade before you can replace the fan motor, here is a guide to help and instructions for your car in the images below.
https://www.2carpros.com/articles/replace-electric-fan-motor
Check out the images (below). Let us know if you need anything else.
Image (Click to enlarge)
Apr 17, 2025 at 2:51 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Check engine light
Engine won't start
