Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
All
Engine Cooling
Cooling Fan
Radiator fan
1998 TOYOTA
26,555 MILES • 2.4L • V6 • 2WD • AUTOMATIC
SKERIS
MEMBER
How does it work with the hydraulic pump? were do the wires come from to activate the pump and start sanding oil to the fan?
May 24, 2017 at 9:22 PM
HMAC300
Experienced Mechanic
the oil is in the fan clutch it is normally silicone when It heats up it locks the fan up so it will work.
May 24, 2017 at 11:31 PM
Add image or video
Ask a new question
