HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
All
Engine Cooling
Cooling Fan
Radiator fan
SKERIS
MEMBER
1998 TOYOTA
2.4L
V6
2WD
AUTOMATIC
26,555 MILES
How does it work with the hydraulic pump? Were do the wires come from to activate the pump and start sanding oil to the fan?
Thursday, May 25th, 2017 AT 4:22 AM
HMAC300
MECHANIC
The oil is in the fan clutch it is normally silicone when It heats up it locks the fan up so it will work.
SPONSORED LINKS
Thursday, May 25th, 2017 AT 6:31 AM
Please
login
or
register
to post a reply.
Related Cooling Fan Content
GUIDE
Radiator Cooling Fans
The engine cooling fan is designed to move air through the radiator when the vehicle is at slower speeds or stopped. This air flow removes heat from the coolant created by...
Online car repair manuals
