Radiator fan not turning on
119,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
ALEX19899
  • 171 POSTS
Hello, I started the car and wanted to see if the radiator fans would come on. I got the temperature to almost half on the gauge but the radiator fans were still not on.
Jun 20, 2018 at 7:45 AM
CARADIODOC
  • 34,414 POSTS
The fastest way to test the entire system is to unplug the two-wire coolant temperature sensor. The Engine Computer will turn the fan on by default in case the engine is overheating and it has no way of knowing it. Doing this will set a diagnostic fault code and turn on the Check Engine light. Once reconnected, the light will be off the next time the engine is restarted. The fault code will self-erase after fifty engine starts.
Jun 20, 2018 at 1:38 PM
