Radiator cooling fans not working
1994 BUICK PARK AVENUE
150,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
CHRIS MCCRAY
Hello. I have the car listed above 3800 v6. Cooling fans are not coming on unless I have A/C running. Any thoughts? Thanks, Chris.
Jul 11, 2020 at 4:42 AM
Good afternoon,
Do you have a test light to do some testing?
I attached a wiring diagram for you to view and need to do some checks.
One thing you can try is disconnect the coolant sensor by the thermostat and see if the fans kick on. Do this with the key on, engine off.
Jul 11, 2020 at 4:52 AM
CHRIS MCCRAY
Yes, i have a test light. Will test both relays when I get home. Thank you!
Jul 11, 2020 at 5:15 AM
You are welcome.
Keep me updated and let me know if you need any other help.
Jul 11, 2020 at 5:17 AM
