radiator cooling fans do not turn on and the A/C blows warm air?
2015 CHEVROLET EQUINOX
50,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BOB BURNS
The ac blows warm, and the clutch does not engage. The radiator fans don't turn on, but the car does not overheat. If you disconnect the A/C high pressure switch the radiator fan turns on high. Checked the fuses and relays seem fine.
Jan 26, 2023 at 2:09 AM
  • 55,432 POSTS
The system will not turn on if it is low on refrigerant, here is a video that will show you how you can check it and add if needed.
This shows you how to recharge the system and check the pressures:
https://youtu.be/uZrQCGwXfek
Here is a guide as well:
You can use a flashlight to inspect the A/C hoses and compressor to see if any are wet, this means they are leaking. Please go over these guides and get back to us.
Jan 27, 2023 at 2:44 AM
