Radiator cooling oscillates off and on
70,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
VERDO131
As my coolant temperature exceeds 200 d, my radiator fan turns on. It remains on for approximately thirty seconds and shuts off for approximately thirty seconds and continues to oscillate off and on and my water temperature rises. Is this a sign of a faulty coolant temperature sensor of other problem?
Mar 10, 2019 at 7:03 AM
Good afternoon,
Yes, the signal is from the temperature sensor. You can try replacing it and see if that repairs it.
If not, then we need to do some electrical checks.
Mar 10, 2019 at 7:33 AM
