Radiator coolant overflowing
1986 TOYOTA COROLLA
17 MILES • 1.3L • 2WD • MANUAL
EX094
Recently the coolant from the radiator has started to overflow through the reservoir tank and foamy bubbles were being formed in the radiator. so I thought it was a blown gasket. Took it for a replacement but the head gasket turned out to be in great condition. I've bled the radiator two to three times still it overflows after driving it.
Jan 24, 2019 at 11:45 AM
  • 110,244 POSTS
Hi and thanks for using 2carpros.com
Like you, my first suspect is the head gasket. However, if you had it checked, then it has to be the result of the engine running hotter than it should.
My first question is this. Are you running straight water in the system? Next, has the thermostat been replaced? Has the radiator been checked or flushed? Does the heater work?
Jan 25, 2019 at 9:48 AM
EX094
No sir, I'm using coolant and not straight water, the thermostat was also checked and it passed the tests. The radiator was flushed multiple times though the heater has some problems
Jan 25, 2019 at 1:26 PM
  • 110,244 POSTS
If everything is good, then something was missed. Honestly, if you are getting coolant being forced from the system and it has bubbles, it has to be the head gasket or even a cracked block or cylinder head. Do me a favor. Check engine compression. Here are links that show how to check for a bad head gasket as well as how to check for compression. You may have to do what is called a leak down test.
https://www.2carpros.com/articles/symptoms-of-low-compression
https://www.2carpros.com/articles/the-reasons-for-low-compression
If we find there is one cylinder that is much different than the others, suspect the gasket. Also, let me know how the gasket was checked. In addition, how was the thermostat checked? The only way to do it is to remove it. At that point, it's crazy not to replace it.
Here is a video that shows how to confirm the gasket is good. I recommend doing it.
https://youtu.be/5zpNjYmmiYY
Let me know what you find. Please feel free to ask other questions. Based on your description, at this point, I really feel a bad gasket was missed.
Let me know. Also, let me know what you mean by the heater issues.
Jan 26, 2019 at 9:32 AM
EX094
Hey Jacob, Thanks for all your help. Got the problem sorted out, it was a clogged radiator after all because I used normal tap water instead of a Coolant so it corroded and jammed all the lines in the radiator plus the pump,, after a cleanup it's back to normal :D Also the gasket was absolutely fine.
Mar 20, 2019 at 1:30 PM
  • 110,244 POSTS
Thanks for getting back with me. That's good news. I wish they all could work out that good. I'm glad you got it fixed. Take care and let us know if you have questions in the future.
Mar 20, 2019 at 2:05 PM
