Broken radiator cap, can I drive my car with a small part of the radiator cap in the tank?
115,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
SHEHAK SHAH
  • 25 POSTS
Yesterday i travelled on motorway for approximately 400km and the next day i checked the coolant level it was full but my radiator cap was broken from inside. as i lifted it out the spring was resting in the upper tank which i took it out with a tweezer, but the little plastic thing in the inside of the cap is still inside the cap. what should i do?
I have replaced the cap with a new one. Can i drive my car to the mechanic with that small part of the previous radiator cap in my tank or not?
What should I do? Need help.
Jun 21, 2023 at 12:56 AM
  • 55,770 POSTS
You should be able to remove the seal part of the old cap, I would not drive it because the system could overheat. Use a pair of needle nose pliers and a small flat blade screwdriver should do the trick. Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jun 21, 2023 at 5:36 AM
SHEHAK SHAH
  • 25 POSTS
But the issue is that i can't find it??
Jun 21, 2023 at 1:40 PM
  • 55,770 POSTS
Can you upload an image of what you are seeing please?
Jun 23, 2023 at 3:09 AM
SHEHAK SHAH
  • 25 POSTS
I can't find It Sir.
Jun 23, 2023 at 5:14 AM
  • 55,770 POSTS
Okay, then it sounds like you can just get a new cap, can you take an image of where the radiator cap goes?
Jun 24, 2023 at 3:57 AM
