Radiator bushings removal instructions needed
350,000 MILES • 6 CYL • AUTOMATIC
DJMARIE
  • 21 POSTS
How do you remove the old upper radiator bushings to replace with new ones?
Thanks
Oct 29, 2020 at 10:53 AM
Take a look at this diagram. You will see there are two bolts that hold them in. You just need to remove those and they should lift off.
Let us know if you have other questions. Thanks
Oct 29, 2020 at 11:08 AM
DJMARIE
  • 21 POSTS
It looks like a hard plastic screw that holds that bushing in?
Oct 29, 2020 at 11:47 AM
DJMARIE
  • 21 POSTS
Thank you for your help.
Oct 29, 2020 at 11:49 AM
Now that you say that, I think they are. I am going from memory but if you get a picture we can confirm it for you.
Oct 30, 2020 at 8:35 AM
DJMARIE
  • 21 POSTS
Hey I know you already responded to my first question about the bushings and all
Much appreciated! But I'm wondering If I need a special tool to remove the screw
Sending you a picture...
Thanks again
Oct 31, 2020 at 5:46 AM (Merged)
Sorry if I didn't respond quick enough to the other post. Thanks for the picture. That should just be a socket. If I remember it is an 18 mm but I could be wrong. You just put the socket in the opening that you are showing and then move it around until it seats on the bolt. That rubber should move around until it allows it on the bolt.
DJMARIE
  • 21 POSTS
Thankyou!
That's what was thinking.
You guys are great !
Thanks again for all your help.
Much appreciated!
Djmarie
Anytime. Let us know if you need more help. Thanks for using 2CarPros.
