radiator and radiator fan replacement instructions needed
250,000 MILES • 6 CYL • AUTOMATIC
05ACURATL
  • 37 POSTS
Need instructions for radiator and radiator fan replacement for the above mentioned car.
Apr 4, 2021 at 6:09 PM
Good morning,
I attached the procedure and a picture below for you of the repair.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
https://www.2carpros.com/articles/replace-electric-fan-motor
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
I would also suggest changing the thermostat since you have the system open.
Let us know if you have any other questions.
Apr 4, 2021 at 9:07 PM
05ACURATL
  • 37 POSTS
thank you very much. Very quick question.. If i'm replacing the radiator fan only (not the radiator) do i still have to drain the coolant and ATF fluid? or do i only remove the 4 bolts that hold the fan shroud?
Apr 5, 2021 at 8:53 AM
Just the 4 bolts for the fan. No fluids involved here at all.
Apr 5, 2021 at 9:01 AM
