radiator and a/c condenser removal
3.7L • 6 CYL • 4WD • AUTOMATIC
MARITAJ
  • 5 POSTS
My old condenser has two clips in the center that supports a U shaped tube. The new condenser matches up perfectly but does not have the supporting clips for the U shaped tube that is directly in front of the condenser. Can these supporting clips be removed and placed in my new condenser or do I need to exchange the condenser for one with the clips already in stalled?
Mar 14, 2015 at 8:28 AM
HMAC300
  • 48,601 POSTS
just use the old ones but put new orings in if not supplied and 1 oz of ND8 pag oil.
Mar 14, 2015 at 8:50 AM
MARITAJ
  • 5 POSTS
Hi and thank you so much for the tips about the pag oil and to use new o rings. Again thank you so much
Mar 14, 2015 at 9:23 AM
