radiator
132,236 MILES • 2WD • MANUAL
LA.VERO
  • 43 POSTS
I was driving and all of sudden heard a clicking sound everytime i step on gas.when at a complete stop it would seem to stall when step on gas.temp.gauge started geting hot then as i pulled up home car died stem under hood and fluid poured from under car.can someone help please
Dec 14, 2017 at 3:26 PM
CARADIODOC
  • 34,414 POSTS
You will have to hold your computer closer so my computer can see what happened. Actually, you need a live person to look at it. The simple fact you found a puddle underneath suggests this is not the most serious of conditions, which is a leaking cylinder head gasket. GM cars usually use the red Dex-Cool antifreeze. GM advertised that as "lifetime" antifreeze, but then they put a sticker under the hood specifying it be replaced every three years. Following that advice leads to a real lot of leaking radiators and heater cores because the corrosion inhibitors, water pump lubricant, and other additives wear out in about two years. Even the Dex-Cool company does not recommend waiting three years to replace the coolant.
You also could have nothing more than a ruptured radiator hose or heater hose. What sent shivers through me was your comment that implied you kept driving after noticing the temperature gauge going too hot. That can easily lead to a warped cylinder head, then a leaking cylinder head gasket. That is a major engine repair and can easily exceed the value of the car. If you only drove a mile or two, and there was still some coolant in the engine, there is a good chance no serious damage was done.
Dec 15, 2017 at 5:03 AM
LA.VERO
  • 43 POSTS
How do i know if i have a blown head gasket?
Dec 15, 2017 at 8:32 AM
CARADIODOC
  • 34,414 POSTS
Coolant only rarely leaks outside the engine from a leaking head gasket, and then, rather slowly. Most commonly they leak coolant into one of the cylinders, then it shows up as white smoke from the tail pipe.
There are two tests for a leaking cylinder head gasket, but neither is appropriate for the type of leak you described. Once that is solved, your mechanic can perform a chemical test at the radiator cap, or on GM cars with no cap, at the reservoir. It involves drawing air from the radiator, while the engine is running, through a glass cylinder with two chambers partially-filled with a special dark blue liquid. When coolant leaks into a cylinder, combustion gases usually also leak back into the cooling system. Those gases will turn that blue liquid a bright yellow.
Another test that works well when you are losing small amounts of coolant and have to add every few days to a few weeks is to add a small bottle of dark purple dye to the coolant, then you search a day or two later with a black light. The dye will show up as a bright yellow stain that you can follow back to the source. If the head gasket is leaking, you will find that dye inside the tail pipe. Auto parts stores will have the correct dye for the fluid being tested, and those that rent or borrow tools should have a black light.
Dec 15, 2017 at 9:04 AM
