radiator spits out hot water
180,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
VIC22
Does the radiator always spit out hot water when you take the cap off after driving it for about fifteen minutes?
May 3, 2017 at 7:33 AM
HMAC300
  • 48,601 POSTS
it can depends on whether thermostat has opened or not. you should never do that however. If you are talking about the reservoir then you may have a head gasket problem and shold have it pressure tested.
May 3, 2017 at 8:40 AM
