Does the radiator always spit out hot water when you take the cap off after driving it for about fifteen minutes?
May 3, 2017 at 7:33 AM
HMAC300
✓Experienced Mechanic
it can depends on whether thermostat has opened or not. you should never do that however. If you are talking about the reservoir then you may have a head gasket problem and shold have it pressure tested.
