Radiator
335,687 MILES • 2.0L • 4 CYL • 2WD
JONATHAN TSHITANGONI
I recently changed the body of it from auto to manual, now the radiator fan will not stop running and I cannot start it from the ignition. It seems the wires are wrong.
Aug 21, 2017 at 12:17 PM
  • 55,732 POSTS
It sounds more like a ground lead has been left off. Follow the wiring harnesses and look for black wires coming out with an I loop. This need to be attached to a clean ground.
Cheers, Ken
Aug 22, 2017 at 8:04 AM
Thanks, I will do that and let you know what is happening.
Aug 22, 2017 at 12:49 PM
