Ok thank you. I found it only does it after I use the A/C. It hasn't done it since I stopped using it. Would that still be what to do?
Aug 19, 2016 at 2:15 PM
SATURNTECH9
✓Experienced Mechanic
So does the AC ever start blowing hot when you were using it? Also is the AC/radiator fan working with the AC running? Does it ever overheat with the AC ON? also how old is your radiator cap?
