Rack and pinion swap
207,000,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
CHRIS KINARD
  • 94 POSTS
Can you tell me how to change it from my old Mustang to my older one?
Aug 25, 2021 at 1:44 AM
  • 110,248 POSTS
I need to better understand what you are doing. If I'm correct, you want to remove the rack from a 2000 to an older one? Let me know exactly what is happening and what model year vehicles we are doing this to.
Aug 25, 2021 at 12:48 PM
CHRIS KINARD
  • 94 POSTS
I want to remove the rack off the 2000 and take off the rack on the 2004 and put it on the 2000.
Aug 25, 2021 at 9:09 PM
  • 110,248 POSTS
I looked up the part number for both model years. They are the same, so it should be straightforward. I attached the part numbers below
2000 Mustang 3.8L 2R3Z3504CARM
2004 Mustang 3.8L 2R3Z3504CARM
I attached the directions for removal and replacement for the rack below. Let me know if that helps or if you have other questions.
Aug 26, 2021 at 1:21 PM
CHRIS KINARD
  • 94 POSTS
Man, ya'll are the boss.
Nov 27, 2021 at 5:08 PM
CHRIS KINARD
  • 94 POSTS
Do i need to flush it?
Nov 27, 2021 at 5:09 PM
  • 110,248 POSTS
Hi Chris,
Sounds like you are making progress. Since it's a used unit, it would be a good idea to flush it. Certainly, it can't hurt. LOL
Here is a link that shows how to do a general system flush. I don't know if you need it, but I thought it may help.
https://www.2carpros.com/articles/power-steering-fluid-flush
I hope this helps. Let me know how things turn out for you.
Nov 28, 2021 at 10:56 AM
