Rack and pinion steering
156,250 MILES • 3.0L • V6 • 2WD • AUTOMATIC
BOITA
Went to get oil change they told me my rack and pinion steering was going out. Mechanic said if I turned hard right, steering wheel stayed in the middle, the same for the left. I did notice it was harder to turn the steering wheel while turning out of a parking spot etc. but, did I get taken?
Aug 27, 2020 at 4:56 AM
Good afternoon,
Did you have this issue prior to the oil change?
There is not really anything they touch in the steering system during the oil change.
Can you post a video on what is happening?
Aug 27, 2020 at 5:04 AM
BOITA
Not sure if I had any issues prior to an oil change, but I did notice the wheel a little tighter when in reverse and then turning.. other than that, no issues. I’ve already had the work done and paid for it. Total: $2,198.00. they fixed the tie rods which were busted and new struts. the last two items had been noted awhile back when I got an oil change at the same place-Big O. Should have gotten a second opinion. I still may. I have a trusted mechanic in the area where I live, but very expensive. I need a smog test and only go to him, maybe I’ll ask him about it as well. Thanks for the quick response!
Aug 27, 2020 at 6:54 AM
Okay, that is a big number for the work.
That job is worth around $1,400.00 to $1,500.00 with all the parts you listed.
Aug 27, 2020 at 6:56 AM
BOITA
Yea, when they see a woman by herself it’s ching, ching, let the cash register ring! Live and learn.. hopefully! thanks again!
Aug 27, 2020 at 10:32 AM
You are welcome.
Always glad to help.
Aug 27, 2020 at 10:34 AM
