Rack and pinion removal
2004 CADILLAC CTS
156,879 MILES • 3.6L • V6 • 2WD • AUTOMATIC
DAMAN2020
  • 43 POSTS
Everything is unbolted, the rack is loose, lines are disconnected. It wont come out. Is there a twist turn, wiggle combination or does it need to go out the passenger side? Or does the subframe need to be loosened. Should I just use the torches and make a notch to get the unit out of the car?
Jun 2, 2020 at 8:15 PM
Good morning,
I usually loosen the cradle and lower it a couple of inches to get the steering gear to clear the drivers side opening.
It is a tight fit but it does come out that side.
Jun 2, 2020 at 9:46 PM
